Problem opening a drawing from Bricscad in AutoCAD
Hi neb,
You could try the "audit" command and see if any errors are fixed and that solves the issue.
I also suggest raising a support ticket with Bricsys (through your account), upload the problem file and they will investigate it for you.
Kind regards
Dan0 -
Thank you, Dan.
AUDIT did the trick. There were 34 errors and all were fixed.
All the best,
Neb0
