Object Mirror Imaging
in 2D Drafting
I am hoping this is a settings issue but on V22.2.02 when I move objects around / copy objects I get multiple mirror images all over the screen making it impossible to know where it is being copied / moved to (see attached sample). This is brutal to work with. Any help would be appreciative. I run the software on 4K monitors and remember a similar problem with ACAD when 4K's came out.
Hi Tman,
It sounds like the annotation scaling is turned on. When text is annotative, and multiple scales are used, it will display any scale that is associated with the text. When moving or copying text, it will display as you've shown. Within the Annotate panel, check the Annotative Scaling and remove the undesired scales.
Let us know if we can assist any further.
Craig
