Flipline - How do you control which items are flipped or not flipped?
Does anyone know if there is a way to limit or select just certain items to be controlled by the flipline parameter? It seems to me that once you add a flipline to a block or drawing, everything in the block is flipped or not flipped. How can you limit only certain specific entities to to be flipped? Thanks in advance.
Howdy, Stranger!
