pasteclip does not work in dynamic ucs any more
When I try to copy a 3D entity with copyclip or baseclip and insert it onto a surface while DUCS is active, the preview shows the object at the right position. As soon as I click to confirm, the object jumps to a seemingly erronous and unrelated coordinate and orientation.
In BricsCAD 21 this worked as described. Is there a degression in V22?
