Line angle axis
How can i change what axis is in use when drawing a line at angle. Default for me is x-axis. Bricscad v20.
Br,
Lennart
Br,
Lennart
try the UCS command : allows to define a "local" coordinate system, by angle, by entity, by ...
so your x/Y/Z axes can be aligned to whatever;
such an actual UCS can also be saved by name, and restored later on;
also, if you want to align to some existing entities, try "Dynamic UCS".
many greetings !0 -
UCS OB PLAN
Be aware though if you pick a 3dline you will be setting a drawing plane that is on a tilt and can catch you out.0 -
Thank you!0
