BSAVEAS
Woo Hoo ! I just discovered BSAVEAS in bricscad. I've wanted this for ages. No Icon for it as far as I know.
I've been using Bricscad for years, but did miss Autocads save block as option in the block editor.
How do you use it?0
Tom Foster said:
How do you use it?
You actually have to be in the block editor first, and then just type in BSAVEAS. Then you get the option to save that block with another name.Tom Foster said:How do you use it?
I should have said it saves the block you are in as another block so the original is also retained.DFLY said:Tom Foster said:How do you use it?
