How do I make all the text in a layer the same?
Hey, I'm new at bricscad and figuring things out as I go, but I have the following question.
When I add text to a layer, do I want it to have the correct font, colour and text height automatically?
Is the text that is already present on the layer also adjusted?
Hi Johan,
Glad you have chosen BricsCAD. There are a few ways to go about this.
You can set up a text style within Drawing Explorer. That will allow for certain fonts to be used, and it can control the text size (annotative, if you prefer). Layers don't control text size, but the text style does. Previously created text can be selected then adjusted via the Properties panel.
Additionally, once a specific text is created, you could add it to a tool palette. It could reduce time and manipulation of properties as you can set height, layer, rotation, etc within the tool palette properties.
I've included a couple of help center links that may be of use.
https://help.bricsys.com/document?title=_guides/BCAD_annotate/GD_creatingtext.html
https://help.bricsys.com/document?title=_guides/BCAD_annotate/GD_workingwithtextstyles.html0
