Disable hidden line removal
Is there a way to disable hidden line removal in BricsCAD BIM drawing generation?
  • Hi,
    You can generate the hidden lines and set the properties for them in drawing explorer/sectionplanes.
    The default values when a new section is created are taken from \Support\Bim\Sections\_SectionSettings.dwg
  • Thanka for the response. What I'm actually referring to is the hidden line removal setting which defaults to -1, is there a way to completely disable it? When generating sections the lines of entities that overlap with BIM Spaces don't get generated and from what I understand is analytical hidden line removal appears to be responsible. So is there a way to disable it so that I can have those background lines visible again?
