Where does "Bricscad.log" come from?
In my folder for logfiles I found a "bricscad.log". It contains entries since last summer, usually only the date and time of starting a Bricscad-session. I can not delete it. Sometimes it logs also commands like Open, Wclose. quit, ..
Where does it come from?
How to deactivate?
How to deactivate?
Befehl: Befehl: -------- [ BricsCAD - Wed May 11 09:08:26 2022] ---------- ---------- [ BricsCAD - Wed May 11 09:32:36 2022] ---------- Befehl: _WCLOSE Befehl: Befehl: Befehl: 022] ---------- ---------- [ BricsCAD - Wed May 11 10:19:27 2022] ---------- ---------- [ BricsCAD - Wed May 11 10:28:36 2022] ---------- ---------- [ BricsCAD - Wed May 11 10:29:02 2022] ---------- Befehl: Befehl: Abbrechen Befehl: Befehl: Befehl: _QUIT ---------- [ BricsCAD - Wed May 11 10:56:30 2022] ----------
Please see LOGFILEMODE, it defines whether a log file is created or not ... when disabled and BricsCAD is closed, you can delete that file afterwards :-)
many greetings !0 -
Thanks Torsten
until now I knew only the drawing-based-single-log-files, and this is exactly what is described in the Bricscad help:
https://help.bricsys.com/document?title=_systemvariablereference/SV_logfilemode.html&documentVersion=V22
