format .xyz
in Point Clouds
Hi
Can I import a point cloud in format .xyz in BricsCAD Pro 22?
Thanks for helping.
Thanks for helping.
Hi vtm,
we are working to support 'custom' text based formats import for the V23 release. Meanwhile you can import the data if it is structured in the right format and saved as *.pts file.
Any of the following 4 structures are automatically detected and hence supported: XYZ, XYZI, XYZRGB, XYZIRGB.
I hope this helps you.
Piet0 -
Hi Piet
Thanks for your return message.
What do you mean with "I can import the date and save as ...?" with which command?
Actually I can't import "xxxxxxx.xyz" File in bricscad.0
