propagate window details
in BricsCAD BIM
Is it possible to propagate window details like a window sill to all the other windows?
Ammh, I have never tried ....
But I think Bricscad's Propagate would find similar situations,
at least if a developers ever thought about this situation (?)0 -
Propagate should work well in this scenario. If window placement depth, etc., varies it might alert to interference or might not catch it.
Another option is to add more detail, e.g., the sill, in this example, to the component definition itself and then replace all inserted instances with the more detailed version. The advantage of propagate, though, is that it can apply the same detail to multiple window types.
Often times when I try propagate, however, it finds only a fraction of the instances I want. I know there's a way to parametrize the reference relationships, but I forget how to do so, give up, and carry on copying manually.
