Profile centre lines
When converting lines into BIM profiles using the "bimapplyprofile" command, the line that is picked changes to the selected profile.
Is there a setting that retains the selected lines so they are still visible if the solid is hidden?
thx
  • Hi Ian,
    When I drag a profile on a line from the profile library or just run the bimapplyprofile command and go to library the lines are kept. How do you use the command?
  • Ian Johnson
    edited June 2022
    Thanks for your quick reply Piet,
    I am using V20 and as the video shows, my path line disappears when the solid is placed.
    Has there been a change in the later versions of Bricscad?
    thx
