How to flip a block with reference curves
                                  in 2D Drafting
                    Hi Everybody,
Is there any way to flip a 2D block (with a mirror effect) to define the direction of a flow. The pump block I usually used is defined with reference curves but I don't know how to specifify the flow direction (orientation of the block) before to click on the reference line. Thanks for your help.
            Yes, a block can be mirrored, either with the Mirror command or by changing its ScaleX or ScaleY property to -1 in the Properties Panel.
If that's not what you mean, please explain further and post a .DWG file with the block in it.0
