units
I haven't found a solution for this - the units I set in my drawings is almost always feet. When I select the entity and display properties, the unit value is listed in miles. If anyone can help I would be appreciative.
John
  • When you start a new dwg it uses a predefined dwt, you can change the dwt setting, Config, Files, Templates set it to your dwt or a metric one.
  • jloacker said:
    .... the units I set in my drawings is almost always feet. When I select the entity and display properties, the unit value is listed in miles. ....
    Can you post a .dwg file in which that happens? And please indicate which entity has its length shown in miles on the Properties panel.
