DWFx
Can BricsCAD import a DWFx (Autodesk DWFx Document)?
BricsCAD doesn't support import of DWF/DWFx files. They should be converted to DWG via some converter.
For example https://anydwg.com/dwf-to-dwg-home.html or https://www.autodwg.com/dwf_dwg_converter/default.aspx0
