Rearrange menu bar
We are developing bricscad plugin and up until V21 we were able to rearrange menu bar via COM interface:
IAcadPopupMenuPtr::RemoveMenuFromMenuBar();
IAcadPopupMenuPtr::InsertInMenuBar(_variant_t(popup_count));
That would translate to: remove menu item at and put it back at the end.
Starting V22 function "InsertInMenuBar" hits an error: access violation, regardles of input.
Is there any other way to rearrange menus in menu bar using COM or ObjectBrx?
I have further investigated the issue:
IAcadPopupMenuPtr::RemoveMenuFromMenuBar(); actually removes popup from menu bar, but as it seems it removes it from MenuGroup as well:
MenuGroups->MenuGroup->PopupMenus::GetCount(long *count) returns 0.
If I reload main cui, I can find missing PopupMenu and can put it back on the menu bar.
Another issue is, that function:
IAcadPopupMenuPtr::InsertInMenuBar(VARIANT index); puts menu before index. That means, that menu can't be positioned to last position, once it is removed from menu bar.0 -
A lisp version
(setq Menu_Path "C:\\XXX-CAD-TOOLS\\"); Path to Menu file
(setq Menu_Name "XXX-CAD-TOOLS"); pop menu to load
(setq Group_Name "XXXMENU"); groupname assigned in .mnu or .mns file
(if (menugroup menu_Name)
(command "_MENUUNLOAD" menu_Name)
(if (> (vl-string-search "BricsCAD" (getvar 'acadver)) 0)
(progn
(command "MENULOAD" (strcat Menu_Path Menu_Name ".CUI"))
(menucmd (strcat "P20=+" menu_Name ".POP1"))
(progn
(setq cnt (vla-get-count(vla-get-menuGroups (vlax-get-acad-object))))
(command "MENULOAD" (strcat Menu_Path Menu_Name))
(menucmd (strcat "P" (rtos (+ cnt 1) 2 0) "=+" menu_Name ".POP1"))
