Help on 2D parametric wall
                    I am trying to automize the drawing of walls by using parametrics.
The problems I'm having are:
-  Some dimensions don't “hook” on the lengths, so when I change the length it doesn't shift with the new length.
-  I'm using a path array to place the constructive posts at a certain h.o.h. (hearth on hearth) distance. The issue is that the first distance from point “0” has to be h.o.h. -19. That's because the plating on the wall has to start from the corner and not the hearth of the post. I tried using the path array offset, but that is not linkable with a user parametric.
-  Hatch is not continuing when the lengths shift.
            Hello @fitimq@live.nl
I fixed the hatch, I was contained within a block and had no linked parameters.
I exploded it and liked its parameters to the Overall_Height and Isolation Thickness.
I'll look at the other things tomorrow, im to tired to focus at the moment.
Met vriendelijke groeten,
Robert0 -
            If you have a spare 2 years you end up with something like this, walls, doors, window, roofs, plus so much more, yes looked at stumps, do have brick piers in walls. Happy to talk about customisation to suit needs. Ask here for more info.
Have a look at this Gif close to what you want.0
