Viewbase - add projected view in another layout
Hallo
I am using viewbase to generate a series of views in a layout and would like to be able to add a projected view (a section or a detail) from a base view but in another layout (because the first one is already full of views).
Do I need to create another BASE VIEW in this new drawing and then generale from it?
In other words, every layout needs a single base view to be able to acquire drawings ?
is there a way to use the same BASE VIEW but adding it to a new drawing ?
thanks
Luca
thanks
Luca
Yes. As far as I know you need a new view base for each layout. What I do is put the view base off the printed area and then take sections and details off the view base and put them in the printed area. I was doing that just today.
Thanks for your answer - will try that!
regards
Luca
Howdy, Stranger!
