Missing .dwg icon
I'm running V18 and have recently uninstalled v.20 which I wasn't using. I'm running Windows 10 and my .dwg icons are now showing blank. When I open a file it opens with v18 which is what I want but I don't want to see blank icons. Understand there might be some fix using REGEDIT in the command bar but some help on this matter would be gladly received.
I would try re-installing V18. As part of the install it should fix the blank icons. If you're looking for a preview of the drawing, then that may have only been added in more recent releases.
BricsCAD V22 Ultimate
CAD Concepts -
I have the same issue! Did you fix it?
Windows can associate a file extension with a program try that.
Howdy, Stranger!
