External components not showing in BIM section
I have a model that is made up of external components and I cut a section using the BIMsection command. The output drawing isn't showing any of the external components in 2D but shows everything else.
If I make the components local, then the output drawing produces the drawing as expected.
Any suggestions?
thx
Any suggestions?
thx
Further to my first post, this doesn't work when I try the section as a block on the drawing either.0
