F2 - TEXTSCR V21 Mech
...ok...i've searched high and low and i still cannot figure out how to get a text screen in V21....have used default cui, tried setting a hot key, etc...any suggestions?
Use the TEXTSCR command.
If you're using a Laptop, then you may need to press the FN + F2 key, as these keys have multiple assignments on a Laptop keyboard. Usually there is an option to switch the FN to being locked on.
If you're a desktop user, then check your keyboard settings. Some allow customisation of the keys.
BricsCAD V22 Ultimate
CAD Concepts0 -
...have tried TEXTSCR and nothing pops up....same with PMHIST...running a desktop...as stated, tried setting a hotkey to run TEXTSCR...command does not work...0
Possibly these windows are displaying off screen? This can happen if you have changed your monitor setup. You can quickly check whether this is the case by creating a new BricsCAD profile. This will run BricsCAD with default settings for window placements etc..
You can find details on how to run BricsCAD with a new profile here.
https://www.cadconcepts.co.nz/news/recovering-from-bricscad-issues
CAD Concepts
