Font size control in the command line
How to resize the fonts height or style in the command line? they are very small.
  • Hi meitalw3,
    If you right-mouse-click on the command line a small dialog box will appear. If you choose Options, then the Settings will open and where it says Command Line, you can alter the size and font etc.
    HTH
  • Thank you very much.
