VBA Error VBE7.dll on V22 pro
Hello,
I use some VBA-Makros to change text in batches of similar drawings.
It opens the first drawing in a specified folder, changes the text, saves the drawing and close it. Then it opens the next drawing and proceeds until the last drawing is closed.
Since upgrade to V22 an error occurs and the application closes without any notice.
I found this two entries in the event viewer:
Name der fehlerhaften Anwendung: bricscad.exe, Version: 22.2.5.0, Zeitstempel: 0x629a0e7e
Name des fehlerhaften Moduls: VBE7.DLL, Version: 7.1.10.33, Zeitstempel: 0x4f0e11ee
Ausnahmecode: 0xc0000005
Fehleroffset: 0x00000000000e6b64
ID des fehlerhaften Prozesses: 0x33f4
Startzeit der fehlerhaften Anwendung: 0x01d8a811e3f1497b
Pfad der fehlerhaften Anwendung: C:\Program Files\Bricsys\BricsCAD V22 de_DE\bricscad.exe
Pfad des fehlerhaften Moduls: C:\Program Files\Common Files\Microsoft Shared\VBA\VBA7.1\VBE7.DLL
Berichtskennung: 5cc2a335-1e3d-49df-8ae7-68dd89a1f633
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
Name des fehlerhaften Moduls: ntdll.dll, Version: 10.0.19041.1806, Zeitstempel: 0x1000a5b9
Fehleroffset: 0x000000000002b660
Pfad des fehlerhaften Moduls: C:\WINDOWS\SYSTEM32\ntdll.dll
Berichtskennung: e5feca13-fd6f-405c-9732-2b516b9c1608
I already checked and tried:
- Windows Update (several times) and restart
- Reinstall BricsCad V22 and VBA
- Went back to V21 --> it works!
- had some beer and forgot about it --> it works too!
The VBA runtime installations for V21 and V22 seem to be the same.
So there migth be a bug in V22 or a new parameter which is not set properly.
I would be very happy about suggestions for a solution.
Thanks for your help
Roman
Roman
