Turning back to regular menu
meitalw3
edited August 2022 in Moving from A-CAD
By mistake i enterned from "load app." command, a CUI file and this messed up all the menu.
I tried to repare and to remove the program but nothing.
How do i bring back the old cui menu?
  • Anthony Apostolaros
    edited August 2022
    You should be able to type MENU and Enter and then pick a CUI file to replace whichever one's currently in use.
  • You can try also 'revert to defaults' option in Customize dialog:
    - run CUI command to open the dialog
    - press "Manage your customizations" button
    - in the appeared window press "Revert to defaults" button
  • Thank you very much.
