BMINSERT Flip command only works on the X axis
Am I missing something or can you only flip entities around the x axis while using BMINSERT?
The only way I can flip on the y axis (i.e. from left to right) is to use Rotate and then Flip (or Flip then Rotate).
As this is awkward because the Rotate option sends the inserted entity down to 0,0 before you can Rotate it which usually isn't near to where I want to insert it.
Am I doing something wrong, or is there only flipping about the X axis?
Hello David,
I thought it was possible, but I'm not on a PC with Bricscad at the Moment.
Ill check back later about that.
But for manipulating 3D objects the "Manipulator" tool is far better than move and rotate.
-Robert0
