appload problem
When I call "appload" from command line I get this form, but I can only close it, not select any file. I have tested V22 and V23 on Ubuntu 20.04. Perhaps is any problem in my installation......
Dear Alf,
maybe switch BricsCAD to Light theme ? To match Ubuntu's Light theme ?
Or have both Ubuntu + BC using the Dark theme ...
seems a clash between mixed Light & Dark theme ...
many greetings !0 -
Did you click on the "Add application file" button? It's identified by a plus sign, which is very faint in the image you provided. Perhaps if you hover over it there's also a screen hint.Alf Wernersson said:... I can only close it, not select any file. ....
