Error Message - Opening Invalid Files
Hey everyone,
When opening a invalid file, Bricscad shows an alert dialog. Is there a way to accept (by-pass) the message using code? I'm using the following C# code to open the file. With valid files it works just fine. The invalid files are not in other formats, they are corrupt DWG files.
public static void OpenDWG()
foreach (FileInfo file in DWGsSource)
DocumentCollection docCol = Application.DocumentManager;
try
docCol.Open(file.FullName, false);
docCol.CloseAll();
catch
//when opening an invalid file the catch is called,
//but only after manually click the button in the alert dialg
//It gotta go to catch block in an automatic way
try
docCol.CloseAll();
catch
maybe you can use db.ReadDwgFile first to test the file0
