File comments
Hi all.
On a PC with AutoCAD installed, I set "Choose default apps by file type."
DWG can be set to AutoCAD DWG Launcher
In that case, I would like to include the contents of the AutoCAD File> Drawing Properties> Comments.
I can see this comment in the File Explorer by right-clicking> Properties> Advanced tab.
Doesn't BricsCAD have this function?
Thank you.
Thank you.
That is a Windows function, not a cad function, I have access to both and If I open Bricscad 1st then a dwg will open with Bricscad. If no cad open depends on Windows.0
