Is it possible to import 'page setups'/layout tabs from another drawing
Coming from AutoCAD this was easy back in the days. Open ADCENTER and select and add the layouts from the other drawing into the current drawing.
Can't seem to get this done in BricsCAD, somehow I feel I'm missing something, but I cannot find a way to do it.
Can it be done? And in what way?
Many thanks!
Many thanks!
- Right-click on any layout tab.
- Select "From template..."
- Change the file-type from DWT to DWG.
- Browse to the file you want to import from.
- Click on "Open."
- Select the layout you want to import and click "OK."0 -
Wow! Thank you so much. As I said, I felt that I was missing something, because in my memory I had seen it being done in a tutorial. But couldn't find it anymore.Anthony Apostolaros said:- Right-click on any layout tab.
- Click on "Open."
Thanks!0
