Components panel missing
I cannot find my components panel in Bricscad V21. I have tried using the command: componentspanelopen. But it doesn't work. It also doesn't show up in the panel options. I have the path set to the correct location, but I still can't access the component panel. How can I fix this?
Since V21.1.04 the Library panel replaces the Components and 2D Parametric Blocks panels. LIBRARYPANELOPEN and LIBRARYPANELCLOSE commands were added.
More info about the new panel you can find in this Help article: https://help.bricsys.com/document/_panels--PNL_library/V22/EN_US?id=16507916811750
