Lisp code to define scale x scale y scale z of a block
in 2D Drafting
Dear All,
Does anyone could help me to write a lisp code to select one or several blocks and to redefine scale x, scale y and scale z properties to a value equal to1?
Thanks for your help. BR
Have you tried using the Properties panel? If you select the blocks first, then you can change the x, y, and z scale from there.
BricsCAD V22 Ultimate
CAD Concepts0 -
Note. If you can't set each x, y ,z value. Open the block and make sure the "scale uniformly" setting is set to no.0 -
For the first part of your request, i.e. to select the block insertions so that you can apply the 3 scale properties to them, you can use the QuickSelect panel, which reverts to the Properties panel that Jason mentioned after the selection is finished.fst said:... to select one or several blocks ...
Alternatively, if your blocks have no spaces in their names, you can select all insertions of a particular block by using the attached lisp-based custom commands and typing the block name, or select all block insertions by not supplying a name. QN filters an existing selection set, and QNX creates a new selection set.
If you want to create a custom command that does exactly what you requested, QN and/or QNX could be a start. The DXF group codes for the 3 scale properties are 41, 42, and 43. The VBA properties are XScaleFactor, YScaleFactor, and ZScaleFactor. I don't know how to make a pop-up list of block names to select from (so that you don't have to type the name and so that the blocks can have spaces in their names). But I think there are forum members for whom that would be very easy. Or ask at The Swamp.
fst, if you're going to write a custom command to assign scale properties to a selected set of block insertions, the two lisp functions in the attached file might serve as examples of how to:
- filter the selection set for the type of entity you want to work on;
- step through a selection set of such entities;
- get a VBA Property from the first item in the set; and
- assign a value for that VBA Property to all the items in the selection set.0 -
Just a suggestion if asking for a lisp etc post in the LISP section of the forum. You may get answer faster.0
