Preview thumbnails in block library
Hello, i am currently creating a custom block library containing only 2D drawings. My issue is that, after including a drawing, the preview thumbnail of it shows up in a isometric (?) view. How can i define the thumbnail to be a top down view in 2D? I am using BricsCAD lite version 22.1.05 (x64). Thanks in advance!
Could you please upload a screenshot of what you mean ?0
The thumbnail should look like the big drawing on the right side.
It appears to be incomplete. I think Bricsys only just recently included 2D assets into it. Probably the only way right now would be to manually edit the thumbnails in the programdata-bricsys-components-resourcs-thumbnails file. But Probably a lot easier to use would be the tool pallets.
I personally use the tool pallet. To put common blocks in.
It would probably be worth while putting in a support request.
Thanks for the quick reply DFLY, i will check the tool palette out now!0
Works like a charm even allowing customizable thumbnails!
Thanks again a many times!
Bricscad supports old fashioned image menu's for oldies like me. Or custom image dcl's
