Visibilty states VS Attribute
                                  in 2D Drafting
                    Dear All,
Is there a way to get 2 visibility states of a block with a single attribute at 2 different positions ? is there anybody to share an example ? (for example a rectangle with an attribute on the left in the visibility state 1 and the attribute on the right in the visibility state 2).
Thanks for your help. BR
            If I replace the attribute with 2 Text objects I can manage to get what I want.
The point is that the parameter LabelPosition (Visibility state Top or Bottom) changes the position of a hatch included in my block whenever I insert it a new drawing and I switch the visibility state (This does not happen in the file itself).
Here you find attached my example. Is there any way to get a correct behavior ? Thanks0
