setting cursor ON or OFF
how to set cursor ON or OFF?
In older versions of Bricscad you could (setvar "colorx" 256) (setvar "colory" 256) (setvar "colorz" 256) but they "fixed" this so that 256 is no longer accepted. This worked for a black background. I never tried it with other background colors.
In Autocad you could use vla-put-ModelCrosshairColor and vla-put-LayoutCrosshairColor, but these are not implemented in Bricscad.
There is no easy way to do this in V22 Bricscad that I have found.
Howdy, Stranger!
