Dynamic Block Behavior
                    Hello all.
Does anyone have issues where some dynamic blocks work fine and others don't. Even though they are similar.
Is there a certain order in which dynamic blocks should be created? ( Stretches before arrays, etc.)
I have 2 different blocks that are the same concept with stretches and arrays. One works fine while the other does not.
I'm attaching a dwg file with 2 examples. One works, the other half works.
Thank you,
Dru
Thank you,
Dru
            Do you have a log in at Cadtutor.net if not do it and post question. Lots of Bricscad users.0
