Top Tool bar disappearing
Using Bricsys on Fedora 36.
I have a problem that the top menu and toolbar are disappearing and I can not bring them
back, unless I reinstall the software.
Here is snapshot
Any idea?
Here is snapshot
Any idea?
> I can not bring them back, unless I reinstall the software.
In general,
I think Mac and Linux version of Bricscad have pretty much the same UI issues
and after a restart of Bricscad, your GUI will very likely do no more look like
you set it by opening certain toolboxes.
E.g. Ribbon is closed and/or Command line collapsed, Bricscad Tools like Snaps
or view hidden, .... again.
But usually I can just reopen them.
A bit more tricky is the left docked Structure Panel, it can sometimes disappear
and i am not able to bring it back. Or Bricscad GUI stalls and does no more
react when trying to open/close tool boxes from the Menu entries.
In this case it will at least need a restart of Bricscad ....
But do you really need to re-install Bricscad ?
Restarting, rebooting, deleting/hiding "config" or settings folder do not help ?
I am not sure if Fedora is supported.
I think at least Open Suse and Ubuntu are.
I use Tumbleweed and Elementary OS (basically Ubuntu) and Bricscad does seem
to work mostly ok.
But I do not much with it on Linux, beside testing Bricscad Shape every now and then ...
I would file a Service Request
