Top Tool bar disappearing
                    Using Bricsys on Fedora 36.
I have a problem that the top menu and toolbar are disappearing and I can not bring them
back, unless I reinstall the software.
Here is snapshot
Any idea?
Here is snapshot
Any idea?
            I'm running Ubuntu
Maybe your default.cui is getting corrupted. Copy your good default.cui file to a known location, when your toolbars get messed up run the script to copy the good one over the bad one.
Works for me.
And yes, I'm waiting for a fix on this.
cp /usr/share/InPowerDocs/default.cui ~/Bricsys/BricsCAD/V22x64/en_US/Support
            V23 Linux BricsCAD. Tool bar is still disappearing0
i have the same problem with V24
V23.. No expert here on the toolbars, but here are some of my observations.
Seems the toolbar settings are stored with the drawing. So if you run BricsCAD by double clicking on a drawing, the drawing default toolbar becomes the new default. This has been frustrating for me also.
I now always run BricsCAD from the menu, not by double clicking a dwg file.
I found these.
