Tables
                    Why do I need to manually regen to see changes to tables?
This is for both editing contents and changing formatting.
            Ok, so this doesn't affect all drawings...0
            In a drawing where I need to manually regen to see the changes, no if I copy and paste the table back into the same drawing then it works as expected without a regen?0
            I copyclip the offending table, then erase it, then paste it back into the same drawing and all works as it should.
Afterwards I purge the drawing and see this...
Regapp "AECBASE" purged.
Regapp "AEC_2DSECTION_XDATA" purged.
Regapp "AEC_MASSGROUP_XDADA" purged.
I wonder if this is because we inserted a table from a block originally created in Au**CAD???
Off to run a test by creating a block in Au**CAD and BricsCAD and see if I get the same problems.0
