Script to paste objects along a polyline at defined distance
I'm looking to make a lisp which will create a coneline, so once ran the cone block will be grabbed from a different dwg file and pasted on to a selected polyline at a user defined distance
I'm rather new to lisp so not got a huge knowledge, I've got a small idea but still learning.
If anyone could help / point me in the right direction that would be perfect
current code:
Thanks,
current code:
(defun c:coneline (/ d1 d2 dis ent op pt1 pt2 tl tot) (setq ent (car (entsel "\nSelect polyline: ")) pt1 (getpoint "\nStarting point :") pt2 (getpoint "\nDirection point: ") dis (getdist "\nDistance: ") tot 0 op (if (minusp (- (vlax-curve-getdistatpoint ent (vlax-curve-getclosestpointto ent pt2)) (setq d1 (vlax-curve-getdistatpoint ent (vlax-curve-getclosestpointto ent pt1))))) - +) tl (if (= op -) (vlax-curve-getdistatparam ent (vlax-curve-getstartparam ent)) (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)))) (while ((if (= op -)<del class="Delete"></del> >= <=) (setq d2 (op d1 tot)) tl) (command "._-insert" "Cone" (setq pt1 (vlax-curve-getpointatdist ent d2)) 0.4 0.4 0) (setq tot (+ tot dis))) (princ) )Is there a way I can do this without it printing anything inside the command bar/log
Thanks,
Look at the NOMUTT setting in help.0
