Creating array path along a polyline
is there a way i can change/ moveaway from using the command feature to do the following?
im grabbing a block from another file and plotting it onto a selected polyline with a certain distance
(defun c:coneline (/ d1 d2 dist pline op startpt endpt tl tot) (defun coning(dist) (setq cmd (getvar 'CMDECHO)) (setvar "CMDECHO" 0) (command "_.layer" "s" "0" "") (setq conepath "C:/.../.../Blocks/Cone.dwg") (setq startpt (vlax-curve-getStartPoint pline) endpt (vlax-curve-getEndPoint pline) tot 0 op (if (minusp (- (vlax-curve-getdistatpoint pline (vlax-curve-getclosestpointto pline endpt)) (setq d1 (vlax-curve-getdistatpoint pline (vlax-curve-getclosestpointto pline startpt))))) - +) tl (if (= op -) (vlax-curve-getdistatparam pline (vlax-curve-getstartparam pline)) (vlax-curve-getdistatparam pline (vlax-curve-getendparam pline)))) (while ((if (= op -) >= <=) (setq d2 (op d1 tot)) tl) (command "._-insert" conepath (setq startpt (vlax-curve-getpointatdist pline d2)) 0.3 0.3 0) (setq tot (+ tot dist))) (setvar 'cmdecho echo) (princ) ) (setq pline (vlax-ename->vla-object (car (entsel "\nSelect polyline: ")))) (setq dcl_id (load_dialog "C:\\...\\...\\Dialogs\\CONELINE.dcl")) (if (not (new_dialog "CONELINE" dcl_id)) (exit)) (action_tile "c10" "(setq spacing 1)") (action_tile "c15" "(setq spacing 1.5)") (action_tile "c20" "(setq spacing 2)") (action_tile "c30" "(setq spacing 3)") (action_tile "c45" "(setq spacing 4.5)") (action_tile "c90" "(setq spacing 9)") (action_tile "c18" "(setq spacing 18)") (start_dialog)(unload_dialog dcl_id) (coning spacing) (princ) )
look into
(vla-InsertBlock mspace (vlax-3d-point bpt) blockname 1 1 1 0.0)0
