Plotting blocks along a polyline - how to speed up/ improve?
I've created a lisp function to place a block from another file to plot along a polyline at a specific distance, i've avoided using a command because of a couple reason, it takes just as long & when i try to undo the who function i either have to mass delete or ctrl + z until each block has been removed off the line
im looking for a way to speed this up, at the moment it is very slow, is there a better way i can optimise this/ do it different?
(defun c:testing ()
(setq pline (vlax-ename->vla-object (car (entsel "\nSelect polyline: "))))
(setq startpt (vlax-curve-getStartPoint pline))
(setq endpt (vlax-curve-getEndPoint pline))
(setq tot 0)
(setq op (if (minusp (- (vlax-curve-getdistatpoint pline (vlax-curve-getclosestpointto pline endpt))
(setq d1 (vlax-curve-getdistatpoint pline (vlax-curve-getclosestpointto pline startpt)))
(setq tl (if (= op -)
(vlax-curve-getdistatparam pline (vlax-curve-getstartparam pline))
(vlax-curve-getdistatparam pline (vlax-curve-getendparam pline))
(while ((if (= op -)
(setq d2 (op d1 tot))
tl
(vla-insertblock
(vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
(vlax-curve-getpointatdist pline d2)
"C:\\...\\...\\...\\Cone.dwg" ;; Replace this path of drawing with yours
0.3
0.3
0.3
(setq tot (+ tot 3))
) 0
hi,
can't you use the _arraypath command?0 -
I have make layouts where you set title block scale and it makes layouts walking along a pline, it aligns the sheet to the orientation of the pline arcs ok, 40+ one go etc
It does need to be set up to suit a end user title block.
It is not free but real cheap.
Next step is have plot layout range.
