Publish Command
acedCommand(RTSTR, _T("_PUBLISH"), RTNONE);
When I try to invoke "PUBLISH" through acedCommand it doesn't show any dialog. Instead it shows the following text in the bottom command window "Enter name of Sheet list:"
But If I type PUBLISH directly in the command window for the same drawing it brings the dialog.
FYI this happens only for PUBLISH command. for other commands like PRINT, it works fine.
I mostly think, there is a issue with BricsCAD
Could you please check it for me?
Thanks
Thanks
