RCP Regions in Point Clouds in V23????
Does Bricscad allow us the ability to turn on and off regions defined thru Recap? I'm not finding that ability anywhere. Talked with help / support and they said recap regions would be accessible thru V23. I do see the ability to create regions with crop solids in V23 but I am not finding anything that lets me see already defined regions thru recap.
I hope this is an oversight.
Regions defined in Recap should be available in the Point cloud Manager Panel. Use POINTCLOUDMANAGERPANELOPEN to open the panel. You can then toggle the visibility of the regions or create new regions.
If you still dont see the regions in the panel, I suggest you create a support request so we can take a closer look at the issue.0 -
They are not showing up on my point clouds. I'll make a support request.0
I have created a support request on this issue. I have tried rcp, rcs, e57. Regions created in Recap just do not show up in the point cloud panel.
I would be interested to hear from anyone else on this, if they are having the same issue.
