Usage of sysvar "HPMAXLINES"?
This is used in Autocad to set the "Hatch Pattern max. Lines which are created through one command"
In Bricscad I get this:
Befehl: HPMAXlines Der Befehl wurde nicht erkannt "HPMAXlines Befehl: (getvar "hpmaxlines") 100000 Befehl: (setvar "hpmaxlines" 200000) 200000 Befehl: (getvar "hpmaxlines") 100000So maybe the sysvar is ignored, but is it OK that it cann't be changed (e.g. when I have to produce a drawing for a client who uses Autocad)?
Post as a support request it looks like a bug. But what version are you using ?0
This variable is not supported in BricsCAD, but it was added to Lisp (getvar/setvar) functions to improve source code compatibility: (getvar) returns the AutoCAD default value, (setvar) does nothing for this variable.0
I think for compatibility it should also accept "setvar". As said above - what to do when my client demands a sysvar with defined values and I can not set it?0
If some variable of feature is missing in BricsCAD, you can create a Support Request and ask to implement such variable.0
FYI: AutoCAD stores the var in the registry, not in the DWG.0
