Problem with paths from previous Brics install
                    I just happened upon this by accident so may be "late to the party". Having been on V22 for the past year I decided to uninstall the V21 version and noticed since then my fonts were not operating correctly. Couldn't change some of the fonts say from romans to romand for example. On a hunch looked at my paths under settings and sure enough it still referenced the fonts under the deleted V21 install. Glad I found this out before upgrading to V23. Is this a bug or did I neglect to do something when switching over to the new version?
            We had a setup lisp so did a normal install and then redid all the pathing, adding custom menus etc its pretty straight forward, even down to loading end user preferred toolbars.
Can provide sample code.0
