Dialog Box Text Size
in Other
I am having an issue fully explained in this LINK
Here is a screenshot of my particular issue
Bricscad 23.1.05
Windows 11 (same issue occured in Windows 10)
4k Display
Played with windows text scaling etc., this had no effect on the items in marked in red on the screenshot.
Also right clicked on the bricsCAD v23.exe file and played with many of the options under the compatibility.
Learned that the best option was to go with High DPI scaling override to 'Application'. All the other setting I found did fix the issue I am mentioning, but the very bad side effect was a blurring Bricscad interface with redraw artifacts when working on plans. (unworkable)
Any others with this issue?
Bricscad 23.1.05
4k Display
I switched my Monitor back to 200% scaling.
(It is only a 24" 4k, but I would prefer a 175% scaling)
But uneven scaling makes Bricscad's Text and GUI
look wrong and non legible.
Did this on Windows and for all my Linuxes.
But I prefer macOS anyway and avoid Windows
where ever I can.
BTW,
Bricscad doesn't work on macOS with display scaling either,
as Bricscad Icons can only 50%, 100%, 200% numbers,
but on Mac I currently use a 1:1 scaled 2570x1400 Wacom
Cintig. So no scaling issues here.
But some UI Text Sizes are Off anyway.0
