TIN Surface - is it possible to detach a tin surface from the break lines that was use to create it
aridzv
edited November 2022 in 3D Modeling
Hi.
is it possible to delete the break lines that was used to crate a tin surface without deleiting the TIN surface it self?
when I delete those line the TIN surface is been deleted as well.
I've attached a simple file with a tin surface and the five 3D polylines that was used to create it.
if I delete those lines (that on a seperate layer) the TIN surface is gone as well.
Thanks,
aridzv.
  • BlazProsen
    It is possible, the procedure is as follows:
    - run the TIN command
    - select 3D polylines
    - apply linear entities as Edges and then you can delete source entities and it will not affect the TIN surface
    Blaž
  • aridzv
    @BlazProsen
    thanks for the reply.
    I couldn't find the "apply linear entities as Edges" option in the TIN command.
    how do I get to it?
    aridzv.
    Edit: BTW, if I move the tin surface I can delete the breaklines and keep the TIN.
  • Up...
    Does anyone have an idea?...
    thanks,
    aridzv
  • fegis
    Hi Aridzv
    Select Points not breaklines.
    Attached DWG for you with no lines.
  • @fegis
    Thanks!!
    worked perfectly.
    aridzv.
Sign In or Register to comment.
Howdy, Stranger!
