Lisp to convert text and lines to drawing stamp with attributes?
in 2D Drafting
I'm nut sure I'm using the correct word but my case is that I have a stupid drawing stamp consisting of lines and text and I wnat to convert it to a smart drawing stamp with attributes. I don't know if this is doabel with lisp so I reach out here for suggestions. I originally use Archicad to create dwg layouts and they are all fine with xreffed model files and all but the stamp is stupid and I need to redo it in Bricscad which is time consuming and boring. So I'd like a way to convert the stupid stamp to a smart stamp.
Mats
Block command and do just that make a block with attributes, by the time find a lisp you will have done 2 things, not wasted time and learnt how to make blocks. There is plenty of Utube about how to make a block.0
