TypedPlan - Hatch background color and Transparency
On my 2D-plans and Elevations it want to mark the sections that have to be demolished.
Through a TypedPlan and with custom BIM properties I am able to override the hatch of the intersection fill. That works just fine.
This also works for the Elevation if I override the hatch, but the result is pretty hard. In the elevations I want a softer result.
When defining the Appearance of a Physical Material there is the option to add a Hatch Background Color to the Elevation.
Is it possible to edit this Hatch Background Color or to add one through TypedPlans?
Preferably with a tranparancy to get that softer result.
Hi Simon,
in regular section generation, the background color of the hatch is set in the material panel.
For typed plans, you can override them.
Howdy, Stranger!
