Connected BIM Inserts in v23
There's an annoying situation I noticed in BricsCAD BIM v23 where inserted components such as doors and windows remain connected that when one is moved in the wall the other moves as if it was both that was moved. Pls is this is a setting how do I turn it off?
  • Hi,
    you mean that you move one window and another one moves? That should not be the case and sounds as a bug. If so, please create a support request.
  • > @Piet said:
    > Hi,
    Yes, that's it. Ok
